Shortend drop links
Alright guys! :thumbup:
On had the furby on the weitecs for some time now and thought it may be about time i sorted the drop links out (im still running Std and the MOT is due in the next couple of months.
People say Mondeo Diesel links are shorter and fit...........
any help please people.
thanks
Yeah, Mk2 or Mk3 - I can't remember. However, I thought the length of the droplinks was only an issue if you lowered the car on standard dampers - aren't the droplink mounts in a different position to where they are on the standard shocks?
my m8s cheepo kit was supplyed with shorter links, and eveyone on here say:
If you are lowering a lot thne need shorter drop links.
If you are only putting a sutible drop on then std ones are fine....... yea im slammed.
thanks
Awesome do these, which appear to be what you;re looking for. No idea if it's a "good" price: Clicky
Hummmmm Awsome GTI store............. :doh: that is a good price............. just not had the best of luck with awsome in the past.............
Edited by vRSsunroof
i cant think of the part number right now , and cant check as im off work but im using early mondeo 1's on mine, about £5 each from memory emoticon-0148-yes.gif
Edited by MarkMac
Guessing your on nights? ill give you a job in the morrow :thumbup:
I've got weitec coilovers on mine and I'm using standard droplinks with no problems
Would the ARB end rub on the alloy on full lock if the drop links are wrong?
I thought it was the the ARB hitting the propshafts that was the problem?
You only need shorter links if the arb is fouling on the drivers side driveshaft, if it's not (and trust me you'd know about it) don't worry :thumbup:
would 30mm lowering springs need shortened drop links? and by using just 30mm lowering springs im assuming that would still be on the original dampers?
not too educated on lowering etc lol
Springs wont need shorter links
Only some coilovers require short links depends on type, kw dont, vmaxx do
For short links go to europerformance and coilovers and select vmaxx shorter links there
Guessing your on nights? ill give you a job in the morrow emoticon-0148-yes.gif
no its my week off mate, im back tuesday, if you still need a part number pm then and ill sort it emoticon-0148-yes.gif
"Kw dont" i run V2 and mine certainly do, used to rub on shafts all the time but mine is quite low
Edited by chrisw_vrs
