VCDS Fault Code
I scanned the Yeti last weekend just to see if alls well but come up with this.
Monday,30,August,2010,20:43:44:42859
VCDS Version: Release 908.2
Data version: 20100326
Address 09: Cent. Elect. Labels: 1K0-937-08x-09.clb
Control Module Part Number: 1K0 937 086 C HW: 1K0 937 086 C
Component and/or Version: BCM PQ35 M 103 0575
Software Coding: 48180ABBF05BF1C040080080010089E4437500AE726D85605C0540000000
Work Shop Code: WSC 33361 790 00999
1 Fault Found:
02071 - Local Databus
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 131
Mileage: 2402 km
Time Indication: 0
Freeze Frame:
Term 15 Off
Voltage: 12.50 V
OFF
ON
Term 50 Off
OFF
OFF
Now Ross tech come up with this as a solution
02071 - Local Databus: No Signal/Communication
Possible Symptoms
Control Modules connected to Local Databus not functioning
Possible Causes
Wiring/Connectors from/to Control Modules in Local Databus faulty
Control Module in Local Databus faulty
Possible Solutions
Check/Repair Wiring/Connectors from/to Control Modules in Local Databus
Check/Replace Control Module in Local Databus
Special Notes
When found in Combination with 00153, check special notes.
Retrieved from "http://wiki.ross-tech.com/wiki/index.php/02071"
Have been to see the dealer and was asked if any warning lights were on etc and was told there diag equipment might not pick it up. I expect they could be preparing the ground but will have to see on Monday.
Any VCDS experts out there any ideas?
Cheers.
Nothing to worry about.. I would guess an intermittent fault in communication with either the rain sensor or the wiper motor. Might turn up again, and maybe not. These fault codes should be considered information, and not faults that must be repaired.
The VAS tool that dealers uses says that if no customer complaint is present, and everything works when checking, erase the fault and be happy :smirk:
Thanks for that,I have already erased the fault and then driven the car but it has reappeared again.
