Which will fit.........
I have the chance of a front setup from a porsche 928 :thumbup: BUT..............will they fit?
If not, does anyone know what ones will? :D
Ta folks ;)
Just fit some 312s and stop trying to be difficult ;)
Anything will fit... with some modification :D
:thumbup: just the answer i was looking for :rofl:;)
"squeezed" a CDA under the bonnet couple of days ago, so why break the tradition of being difficult ;) :p :D
Looking to get some carriers made up :thumbup: i know a CRACKING engineer, gonna find out tomorrow if he can/has time to do it :D
Edited by vRS Dovit
Did you see my post / 'how to' on the 986 4-pot calipers?
Worth a thought as, even if you can get those 928 calipers cheap, I think the discs and pads may get pricey; these use our very same 312mm discs :thumbup:
Other options in the Porsche camp are 996 rears on the front but that's not my area of expertise (in fact, not much is :giggle: )
Edited by muckipup
I don't know - glutton for punishment! :p
Have seen Boxster/Caymen setups used too. But as you rightly point out, it's the mounting points/location that need thought, about how you're actually going to mount them. Plus thinking about the brake line location etc.
On the CDA - you're not convinced that a decent panel filter is a more suitable alternative then?? :smirk:;)
Cheers,
Steve
Yeah, i've been puzzling over this tbh. Spoke to an engineer and he's going to get back to me about the carriers and set up :thumbup: Could be interesting ;)
In regards to the "induction" issue................i've ran a panel filter, induction kit, closed induction kit and a CDA
All i can deduce is that the panel filter doesnt REALLY do much, induction kits etc give a "throaty" noise and better throttle response, closed induction kit/CDA better air feed, less heat soak, better throttle and again a different engine note
In effect your replacing the airbox with another airbox with an induction kit crammed into it :D
besides, got the CDA for helping out another member with some bits and bobs and an "alterenative" solution on his car ;):D
Mad professor comes to mind................................ :rofl:
