Improving handling
Anyone here done anything to improve the handling of their Fabia? Did you go for a whole new suspension set-up, or do a bit of homework on parts you could fit off other VAG cars?
I test drove pre-FL Fabia IIs and found them to have a lot of body roll. When I ordered I spec'd the -15mm sport suspension. The difference is significant with little loss of ride comfort and only £95. Also i have yet to find the limit of the grip it certainly clings far longer than my previous car.
I think lowering is the way forward and RARB if it is available for the Fabia IIs if you are retro fitting. Loads of threads on the matter, just look around :yes:
