[Octavia vRS 245 - 2019] Constant whistling noise under the rear seat when warm — Fuel pump?
Hi everyone,
I could not find any topic covering this specific diagnosis so here is my first real post here!
Looking for some real-world feedback before I order a replacement part for my 2019 Octavia vRS 245 (2.0 TSI 245hp, 129,000 km / ~80k miles, DKTB engine code).
The issue: Once the car is fully up to operating temperature, there is a constant, fairly high-pitched whistling noise coming clearly from the rear (under the back seat / fuel tank area). Aside from the noise, the car runs great: no warning lights, no misfires, and it starts right up both cold and warm.
What I've checked so far:
  • A mechanic listened to the noise and agrees it's likely the low-pressure fuel pump (LPFP) inside the tank.
  • I ran a few checks with OBDeleven showing the pump is working hard constantly (~70% duty cycle at idle, 85-90% under load), while everything else on the engine side (fuel rail pressure, fuel trims, EVAP purge valve) looks completely healthy.
  • The underside of the fuel tank feels completely cool to the touch.
Before I go ahead and swap in a new Bosch fuel pump unit, has anyone else experienced this exact symptom on their vRS (or a Golf GTI / Leon Cupra from the same generation)?
Did replacing the pump permanently fix the whistling, or is there anything else around the tank worth checking (tank breather/ventilation, fuel pump control module, etc.)?
Thanks in advance for any insights!
Cheers,
AD
Recently Browsing 1
