My brakes
Well over the weekend i fitted my 312mm brakes. I did it all myself and with a friend.
They are all bled correctly etc but they seem to be catching, as if the pad is touching to disc as i drive. Also there is a bit of squeal when lightly pressig the brakes.
Will these noises go away or do i need to take them off and put more copper greaso on, or is it just them bedding in?
They stop amazin, not tried hard breaking yet till there bedded in but the performance is there.
Give them at least 100 miles to bed in. High spots on pads are not uncommon.
Yer sounds like just one part is catching. Is it worth having a drive with brakes slightly on? Or will that cause too much heat etc..
