Worried........should i be ?
having just read all the posts relating to upsolute chips i can honestly say i am more than a little concerned.....having had my octy vRS upsolute chipped after it was recomended by a friend.
should i be concerned and are my current problems (see my other posting in this forum) likely to be caused by the chip etc etc.
any experiences of upsolute would be appreciated.
:confused:
I assume you've read http://briskoda.net/forums/showthread.php?t=2078 ? I'm making a guess that you've been told it is your dump valve that is causing the problem? I'll have a look at your posts in a bit just to check :) I had problems with mine, which they said was my dump valve, so I isolated the dump valve and still had the problem. Got it remapped by someone else and ran the new map with the same DV, guess what? No problem at all, strange that :rolleyes:
TAVIARS, you are correct. Dealer says maybe DV. have 4 days left on my 30 day garantee and am thinking of using it. have sent you email via your web site. please ignore.
