Part number info
Just been doing some work on the Furby and with most things ICE related there will be a few snaps and splatters of blood as a result...
Anyway - does anyone know the part number/cost for the plastic cover which goes over the seat belt bolt on the B pillar as the drivers side one snapped when it was being removed :(
Also where can you get the metal clips from? as i wouln't mind "refreshing a few of them"
GFS
GFS
Assuming its not an odd colour all other Fabia's come with, I'd get on the blower to skospares and see if they have any from their scrappers. In my car that bit is a very light grey, might be black in yours? Is it the upper or lower one? (shaped like a "T"?) I know the lower one is a pain in the ass, and I ended up leaving it and just shoving the wiring in from under it. :( The passenger side BTW has no OEM wiring in it, meaning more space. The OEM wiring goes down the driver's side, then along the rear seats (I think under the carpeted bit) and down the passenger side to the boot light/boot lock etc.
Its not a large piece of panneling but just a cap which goes over the top of the seat belt runner. You know there is the large 17mm bolt underneath it which you remove to take off the panel.
I had all the side panels up apart from the one with the boot/fuel cap openers on it.
The passenger side had wires going through it, along with the washerjet hose for the rear
While you're around i see most of the guys here have resorted to the OEM wiring to the speakers in the doors, in my mind that won't cut the mustard. is there no way to get some decent cables into the doors :(
If it is the piece of plastic trim which covers the bolt, the it should be:
6N0 857 719 B41 cover cap satin black -
