Please help me!
Hi, was changing the front pads on my octavia tonite as tightning the bolts back onto the hub and ended up ruining the threads on the hub!!!!! Im just wondering is the hub shared across the vw range???? and is the hub the same as whats on all the mark2 octy???cheers for any help anyone can give me
Hey mate what model is it as i have a almost brand new passenger side hub off a leon fr 170 tdi and so if you can see a part number on yours then il check mine and see if it compatible and can work out a deal. Should be exactly the same to be honest as cant see them using different hubs on the range due to manufacture cost.
Thinking about it check the part number on the drive shaft as easy to see and if its the same then def the same hub.
