Code P0546
just a quick question ive got a error code showing as P0546 exhaust temp sensor, would anyone have the correct replacment part number and the best place to obtain one from please :rofl:
Martin
Just to update in case anyone gets the same problem
i've found this on another forum
"I have seen suggestions that you can omit the sensor altogether and just screw in a bolt of the same size to seal the exhaust and then put a 2.2 Ohm resistor in series with the circuit to keep lights from coming on, but I cannot condone this work-around."
This is not quite correct the true resistor value is 220 Ohm, which has cleared all the errors.
Im going to order a new sensor next week, the part number is 03L 906 088 BC price ive been quoted is £103.00 plus vat
Martin
