Last 2.0 PD 140 made - BKD or BKP?
Were the last 2.0 PD 140 engines fitted to Octavia's the BKD or BKP model engine?
Engine Code is on a label on the passenger door if anyone's willing to look on a 09/59 plate model.
Also, does the BKD type have more of an issue with turbo's failing than the BKP ?
Edited by Ultima
Pretty sure the BKP only appeared in the Passat and changed plenty of turbos on them. BKP also had a sizeable recall to change the oil pump drive gears as they were failing.
The BKD engine seems to have alot of turbo failures too. What does a new turbo cost including fitting roughly?
I have a 10 plate car with the 2.0pd engine fitted, i got mine then found out they where finally swapping over to the cr engine.
Is it a BKD? Should have a label on the end of the passenger door that says it.
Edited by Ultima
will take a look in the morning and post for you fella.
Roughly about £1500.
just noticed on my desk a post it note with some details on it lol, my engine is the BKD engine 2.0 pd tdi.
major issues with BKP passat injectors!
