H&R camber adjusting bolts?
hey guys has anyone ever used H&R adjustable triple c camber bolts? as i have a lot of negative camber after fitting coilovers have had it wheel aligned but its till knocking tyres out on the inside edge, very tempted to just put it bacl on standard shockers and springs as its doing my head in now.
I think that these bolts will do the job well - but not on Fabia, Polo 9N or Ibiza 6L - they are for variants of a previous Polo - maybe 6N and Ibiza 6K which already have a crude "camber adjusting bolt" set-up where the strut connects to the hub assembly.
Something not right there!
had 2 vrs's as low as they go and no tire scrubbing issue's
Id be looking at other problems
bad tracking, worn bushes, bent rear beam (where it may have been jacked at some point)
Have you had the camber laser aligned?
You can't adjust the camber on the Fabia. Only front toe can be altered.
No, it depends what coilovers are bought.
I have kw v1 coilovers, cupra bushes and have had the wheel alignment done about a year ago but don't want to keep throwing money on tyres and wheel alignment all the time
My Fabia always took the inner edge out first, Ibiza seems to be doing then same. But is running quite a bit of net on the front, just one of those things lowering them.
They do look like they would do the job think I might have a go at doing this too my wishbones though
So which ones can you adjust the camber with? I'm only aware of adjustable top mounts that can adjust the camber.
those adjustable wishbones look guy Jerry
Guy jerry?
Guy jerry?
cheap
They are brand new as OEM ones , they are the same as the ones fitted from new
Cost me a fortune , thank you for that :(
Sarah
What coilovers you running may I ask Sarah?
They look like standard wishbones that have been slotted (badly)
I am on Koni STRT , so no coilovers
Sarah
