Excessive outer edge tyre wear
In the last month or so i've started getting some excessive tyre wear on the outer inch of the tyres, currently both front tyres have 4-5mm of tread across the whole of the tyre except for the outside inch which is sitting at the limit markers (1.6mm).
Is this a simple tracking issue or a known problem when something else goes. Car is running standard suspension and i do drive it a bit hard.
Mike
Tracking - Does the car pull to the left or right if the wheel is not straight your tracking is out
Over/under inflated tyres
Console bushes worn - Common fault
Agressive driving style
Not checked yet, need get it booked in real soon however the car drives perfectly straight.
Tyres always inflated to recommended levels.
Bushes are fine, had them checked this morning.
Aggressive driving style
Guilty of this one, not saying all the time but may 2-3 times a month.
Edited by mikee
