noise from front suspension
Hi there guys , i currently have an issue with my front suspension . The front of the car is making a rattling noise on uneven road surfaces , I have had the car checked and there was nothing visible and all bushes seemed ok. I had the two drop links replaced as i was told that those were the most likely cause but the noise is still there . I have now been told it is most likely that its the strut itself that is worn causing the rattle .The car is a 2007MY petrol vrs & has only done 27000 miles . looking for some advice as to what else it could be and best solution to the problem . If i have to replace parts i might change to koni fsd's and eibach springs or coilovers not sure what yet though so any advice on this would be great too .
Allan
Suspension top mount mate, cheap to buy but a pain to change even if ur struts been in and out you're hub a few times lol
Cheers mate I'll get that looked at
try looking at gear linkages....mine has annoying rattle from front passenger side. Drives me mad. Car has only doen 34k
  • 4 months later...
Sorry for bringing back an old thread but I still have the same issue as posted previously. I have replaced the top mounts and struts and also the drop links but still have the rattling noise. The dealer can't seem to find the issue as everything looks ok.
I think I have the same problem. I have had everything checked and it all as solid as a rock. I'm stumped.
im starting to think its a steering rack issue as im only getting the noise when i go over a bumpy road and my wheels are straight. it doesnt happen any other time,
