Removing seats
I have used the search function to death and have finally got fed up. I've also PM'd a member and haven't had a reply yet. I'm wanting to do this on Saturday, so time is getting a little short for me.
So, anybody know how to remove the upper part of rear seats (can do the bottoms just fine!), and both front seats?
Do I have to look out for any wires which might be connected or anything like that?
Reason for removal is to give them a good clean with a rug doctor, and would rather not do it with the seats in situ. so I can clean the carpets too (some mould from water ingress - now solved).
How easy would it be to clean the seats in situ., and what problems would I come across?
Sorry again for lacking in patience with the search function, and thanks for any help!
Edited by Bezzy
Indeed :giggle:
Looks like my searching skills are as good as my mechanical ones :rofl:
Good job! :thumbup: Very helpful links!
What do you think about the replacement of the 10-star bolt? Is that going to be necessary do you think?
How about some of this if you decide to reuse the bolts?
http://cgi.ebay.co.uk/Thread-locker-Medium-Strength-Blue-6ml_W0QQitemZ230530909399QQcmdZViewItem?rvr_id=153863221865&rvr_id=153863221865&cguid=30dd096512b0a0aad2a72697ff319890
Price up the bolts as well though mate,
they may be cheaper than you think? Make sure the spline socket
you use to remove them is a snug fit and fully inserted into the bolt
on each turn. They will be damaged if you don't take care when removing.
Good luck Dan :thumbup:
Edited by grr666
