New Motor
Well chopped my Fabia vRS in for a new project, a 2002 vw golf gt tdi 130 3 door
Fabia - Stage 2 circa 200+ bhp
07e70565.jpg?t=1287157455
Golf
Now your probaly thinking im insane, BUT the Golf has 12k receipts for work carried out at derv doctor
some of the stuff is
Dbilas performance camshaft
Tubular manifold with exhaust gas temperature sensor
TurboDynamics Hybrid Garrett VNT20 Turbocharger
Custom made down pipe to meet Milltek system
High Flow Injectors (+40% Flow over stock PD130/150)
PWR Air to Liquid Intercooler, with custom 5 litre header tank and large pre-rad
ERL Water Injection System with 10 litre in boot water tank
Helix single mass flywheel and up-rated clutch
Carbon Air Intake and cone filter behind bumper
Plus lots more, main plan is to de-chav it, ive already got rid of some decals, fitted a standard golf grille, just need some anniversary wheels and front valance and its done
Edited by BigJase88
Whats with the IC pipe around the engine and the pukka pie base in the middle? :D
Peak torque and power seems to be up the rev range a bit more..! :thumbup: v v tasty..
How Chavveh does it look atm?
Edited by JLneonhug
Nice one Jase - as a former mk-iv golf owner, i'll always have a soft spot for them.
Any full external pics of car?
How do you find it compares to the Fabia?
I was a little surprised with the peak torque figure, but as long as it covers a decent useable range, I bet it flys!
Any pics of the car?
Doesnt run an intercooler as such, its a charge cooler, AIR to WATER
Strange set up :rofl:
Pictures are quite embarrassing, they were when i first got it,
i've since de-stickered, stuck full rubstrips on, an original grille
still need an anniversary front splitter and standard headlights to finish it :thumbup:
Whoever done it had a lot of money but not much taste
watch this space B)
That PWR charge cooler should eliminate the lag you would normally get with a huge FMIC, be interesting to see what charge temps you see running that set up.
most people have peak torque around 2.2rpm and buzz on about it, peak torque down low is pants, it just spins the wheels, the longer you can hold onto the torque the better, peak torque at 3.9k rpm is phenomenal :o
is there a separate pump to push teh water round the charge cooler or is it all piped into the radiator system?
Thats a pretty clever system.. :thumbup:
http://www.owendevelopments.co.uk/products/product-detail.asp?prodId=247&catId=25&subId=-1
From the pics I assume the big silver box holds storage and pump :)
So from this set up I assume someone is going to fit a big fat turbo and see what happens? :rofl:
Edited by JLneonhug
it already has a big massive hybrid vnt 20 turbo on it, now i dont know what thats off or what its good for but cant be far kicking the arse off 300bhp surely
has a seperate 12v pump (not in storage tank)
some less embarrassing pics
