Help Please
Couple of questions Guys
are ALL the exterior Badges on my MK1 Fabia Estate "stuck on" ?-------i want to remove the Side ones that say "comfort" and possably the "1,9 TDI Fabia" on the rear tail gate
where can i buy "fitted" after market front seat covers,the nylon Halfords ones im using at moment are C-----P!
try ebay for the seat covers.
As for the badges, the only one that is not stuck on is the Skoda badge. To remove the others, gentley heat with a hairdryer and CAREFULLY remove using a credit card or somthing to the equivalent...................i do stress to be careful as not to damage the paintwork :thumbup:
Edited by vRS Dovit
I find using fishing line is good as it cuts through the foam that holds it on, then to remove the foam spray on somthing by turtle wax called bug and tar remover, heat this up for a few minutes, wipe away the residue and use the heel of your thumb to remove the foam, works a treat, every time and gets a perfect finish :)
