wheel spacers
i'm looking to get some wheel spacers for my fabia vrs (5mm each side at the front and 10mm each side at the rear)
could any one recommend the best brand to get and where to get them from?
cheers in advance
Ross
You won't be able to fit 10mm on the rear.
Non hubcentric spacers will not leave enough of the centre spigot to mount the wheel on and anything less than a 15mm hubcentric spacer won't be deep enough to sit flush on the disc.
what size of wheel spacers do you recomend then?
Ross
Our MPI is running 16" TT alloys and 10mm spacers up front with 20mm on the back.
Edited by Tech1e
looks smart like the purple touches its different. where did you get the spacers from and how much were they?
Rears were new on eBay, about £40 they are steel ones that bolt on so use standard bolts. The fronts I found used on eBay were on an Audi TT.
