Loop attenuation
Recently I switched from a plusnet where I synced at 7616, and had a loop attenuation of 25dB. Now I am on LLU, but my attenuation seems to have jumped to a rather stupidly high 49dB, thus meaning I am not syncing much faster, and it also means my line is now over 32 times worse than it was before?
Initial "guesses" where the line should sync around 13mbps, not a mankly 8mbps :'(
Samknows reports my line as 0.8km long (as the crowflies), so I know it is longer than that, but I am sure it does not route to france and back!
Could the engineer who moved my line to the LLU equipment have gaffed it up?
Edited by mbames
Well it will be a combination of factors including the carrier that the ADSL2+ is running on, their equipment and the line itself.
I'd have a go at your LLU provider first and see what they come back with as their excuse.
My LLU provider says it is fine, and there are no faults on the line.
I am going to try with a variety of other routers/modems and see what figures they report, before I can I work out of a plan of action/ask for help!
Just tried with my old Cisco 837 (actually connected with it at the moment), even though it is a non ADSL2 device, is is reporting:
cisco_gw#show dsl int ATM 0
ATU-R (DS) ATU-C (US)
Modem Status: Showtime (DMTDSL_SHOWTIME)
DSL Mode: ITU G.992.1 (G.DMT)
ITU STD NUM: 0x01 0x01
Vendor ID: 'ALCB' 'BDCM'
Vendor Specific: 0x0000 0xA189
Vendor Country: 0x00 0xB5
Capacity Used: 88% 93%
Noise Margin: 11.5 dB 9.0 dB
Output Power: 20.0 dBm 12.0 dBm
Attenuation: 25.5 dB 16.5 dB
Defect Status: None None
Last Fail Code: None
Selftest Result: 0x00
Subfunction: 0x15
Interrupts: 1281 (2 spurious)
Activations: 1
Init FW: embedded
Operartion FW: embedded
SW Version: 3.9.220
FW Version: 0x1A04
Stats from my 660:
P660R-61C> wan adsl linedata near
noise margin downstream: 16 db
output power upstream: 7 db
attenuation downstream: 26 db
P660R-61C> wan adsl linedata far
noise margin upstream: 14 db
output power downstream: 18 db
attenuation upstream: 14 db
Upstream Speed: 797 kbps
Downstream Speed: 7548 kbps
Stats from my Vigor 2800:
> adsl status
--------------------------- ATU-R Info (annex A) ----------------------------
Running Mode : ADSL2+ State : SHOWTIME
DS Actual Rate : 8188400 bps US Actual Rate : 796100 bps
DS maximum Rate : 8188400 bps US maximum Rate : 796100 bps
DS Path Mode : Interleave US Path Mode : Interleave
NE Current Attenuation : 24.0 dB Cur SNR Margin : 14.5 dB
DS actual PSDM© : 00000000 US actual PSDM® : 00000000
ADSL Firmware Version : E.38.2.23
-------------------------------- ATU-C Info ---------------------------------
Far Current Attenuation : 15.0 dB Far SNR Margin : 25.0 dB
CO ITU Version[0] : 00000000 CO ITU Version[1] : 00000000
DSLAM CHIPSET VENDOR : < Unknown >
INTL, DSTREAM bytes/depth= 0, symbols/codewords = 0, latency= 0*0.25ms.
, USTREAM bytes/depth= 0, symbols/codewords = 0, latency= 0*0.25ms.
CODE, DSTREAM fast parity bytes= 0, fast codeword= 0.
DSTREAM intl parity bytes= 0, intl codeword= 0.
CODE, USTREAM fast parity bytes= 0, fast codeword= 0.
USTREAM intl parity bytes= 0, intl codeword= 0.
Setting>>
FDQ : Enable, TCM : Enable, EC : Disable, Framing Mode : 3.
Running>>
FDQ : Off, TCM : Off, EC : Off.
DS : Framing Mode 3, US : Framing Mode 3.
ADI ADSL Firmware Version: E.38.2.23
However the Stupid/cheap/nasty Sky Router (sagem PoS) is reporting -> 49.5dB down :'(
Edited by mbames
Stats from my 660:
Ohh, right yes, well a **** router won't help :(
Looks like you might want to buy a better router if it's something you can afford.
Phone Sky this morning, and spoke to someone with brain. He immediately tweaked something and my disconnection dropped and reconnected at 15mbps. I did say I was using my own router as the Sky one was broken, so he is sending me out a new router too. I have a Vigor 2820 on order too...... :p
