"Sound System" Upgrade
Hey Briskodians
I get my new superb in 2 weeks and i ordered it with the upgraded Sound System.
But i know for sure that in the long run i will not be satisfied with it (Only bought it to have good place to start and have some of the wire harness ready).
So the questions is:
- The default "Sound System" amplifier under the seat is that reuseable? Or is it too weak?
- Would it be recommended to install a sub in the back? (Preferably an active one.)
- Is there any way to install a center speaker somehow? (It really changes the sound dynamics in a car. It's much better than just having speakers at the side)
- What about speaker sizes? What is the recommended MAX size for installation in the default placeholders for the existing speakers.
- What speaker brands do you recommend?
\Tom
Edited by tomcatdk
If you were going to replace the system, I would have ordered without it. Upgrading a car that has this system fitted is far more difficult than one that just has the standard speakers fitted.
The under seat amp, is fed from the headunit via line-outs from the headunit. The headunit because its driving this amp has a totally different setup in its configuration setup, so its not easy to remove the upgraded amplifier. The amp is controlled via canbus, as is the sound profile (bass/treble/balance) etc. The speaker outputs on the headunit are also disabled, so unless you want to do a major rewire/configuration of the headunit you will be limited to replacing the speakers.
