cigarette lighter not working
Hi Everyone,
My Cigarette lighter is not working (which i use to plug my sat nav in).Does anyone know how to remove it,so i can have a look at it, and is it possible to get a replacement?
Thanks in advance for any help
Graeme
fuse gone?
Mines doesn't work, not checked the fuse but probably the cause.
not checked the fuse, ..but my 3 year old unplugged her tv/dvd player by pulling the wire,....and since then the cigarette lighter hasnt worked.
But I will check the fuse just incase, cheers
Graeme
Centre console needs to come out, and then even I'm not sure how to take the whole cig lighter socket out. Struggled to just replace the bulb in it.
fuse gone?
+1
In case you weren't sure, the fuse board is behind the back to front D
shaped panel on the end of the dash which is revealed when the driver door
is opened. Pry off with a butter knife wrapped in a teacloth or other trim removal tool,
Cigar lighter is number 42, 15 amp
See here for diagram ---> http://www.fabia-vrs.com/technical-info/fuse-panel-layout/
:thumbup:
Hi everyone,
I replaced the fuse and ...........PROBLEM SOLVED!
Thanks very much for all your help
Graeme
  • 6 years later...
mine is not working how and where can i get one?
  • Sponsor
Have you checked the fuse?
No I haven't do you know what fues it would be.?
  • Sponsor
No. 42, 7th one up right hand column. See here:
I have a new cigarette lighter now thank you for your help mate.
I have a new problem, my engine idle is low and my engine races?.
Create a new topic for this problem. Tell us about your car and engine type and any specific characteristics of your problem.
