Door sill protection - fitting?
Has anyone fitted the Skoda accessory door sill covers - these ?
How do they fit - double-sided sticky tape, screws, rivets, or what?
I can see after a month of ownership that the sills are likely to take quite a bashing so these protectors seem a good idea.
I ordered for mine but they refunded the money as vrs come with vrs sill guards .I would have thought they would have an adhesive backing like replacement badges :thumbup:
You mean like these, clean surface and heat it up with a hairdryer ( car surface), the 2 sided tape sticks on better.
I've fitted a set, and they had double sided foam tape on the back. Important to clean the sills up with meths or similar to get a good bond. I bought some 'no nails' double sided tape which I'm sure would be just as good.
BTW - Scouts only come as standard with the front set.
Les.
Edited by London Les
Just what I wanted to know. Thanks for your help guys :thumbup:
The guide also indicates a temperature of between 20 and 40 degrees C :|
Are they standard on the vRS at the back?
I ask as I have none at the back, only the fronts.
They were on mine, but mine is not an FL :S
