Misfire, judder & poor acceleration Octavia Vrs mk1
Driving home from work today I suddenly got a hesitation when accelerating hard, also the engine light flashes until I ease up then goes out.
Does anyone have any clues before I send it for a diagnostic?
sounds like a coil pack has failed, while its ticking over remove each individual one until you find the culprit :thumbup:
It ticks over fine, can a coil pack do this and then under acceleration fail?
Yep!
Yep!
Ok thanks, so if it ticks over fine by doing as you suggested how do I know which one?
every time you remove a good one the idle will get worse, when you find the bad one it'll stay the same as it is now.
I think he meant that if you are getting a missfire at idle you can remove each coilpack in turn, if the engine changes (worse) then the coilpack is good if it doesn't change then you have found the duffer :D
if it only happens on boosting then get a VAGCOM scan to see which cylinder is missing. once you know you can swap coilpack with another, go for a run then rescan and see if fault moved with the coil, stayed on the same cylinder or stopped missing. Also worth checking your plug gaps. HTH
EDIT: Damn it too slow again :D :D :D
Edited by karlbar2k
Thanks, I will book a diagnostic tomorrow.
Had exactly the same problem tho not on a VRS. Didn't ID the issue until the coil completely went and the engine sounded like a bag of spanners. Coils come as a pack and tho I can't remember the exact cost, it wasn't too bad!!
That's deffo a coil pack.
Had two go in a week about a month a go. :'(
got them from a vw dealer £34.18 each including vat
was told to get a spare to keep in glove box just incase
on the top of the coil pack where you plug it in. there his a date stamp. mine was 33.03 (week 33 2003)
just look for the oldest it worked for me.
got them from a vw dealer £34.18 each including vat.
Do I get a prize?
Do I get a prize?
Yer two dead coil packs or maybe three :giggle:
Woohoo!........i've got loads of dead ones, how many do you want.
