Laser Alignment in Kent
Hi guys, I apologise because no doubt its been asked many times before, can anyone recommend a garage in Kent that will do 4 wheel laser alignment, I'm in the Medway area.
  • 3 months later...
Hi, sorry to raise this again, but can anyone recommend anywhere in Kent, preferably around the Medway/Maidstone area ?
Sorry don't know any localy, you could always give Sherlodge a buzz and see if they can do it or know of anywhere.
Alignmycar.co.uk is yer buddy
Edited by Golf-Fiend
Thanks guy's, I've looked at alignmycar.co.uk, the nearest garage is a Formula One Centre in Maidstone, anyone had any dealings with them at all ?
STS Tyre Pros in Maidstone according to the Wheels in Motion site. Any good for you??
Hi Tricky, yep STS is close to me, has anyone used them for alignment ?
  • 5 months later...
Hi, well its my own fault, I've left it too long and my rears have sawtoothed. I've checked on alignmycar and they reckon STS in Maidstone is my closest centre. Has anyone used them for this at all ?
Had my wheels aligned at STS in Canterbury last week. The guys in there were good. They took me into the work shop and talked me through the whole process. I then watched as the computer controlled ramp measured my car as it was rocked and bounced around by the machine. The computer even measured the range of movement on the the steering wheel. Was quite interesting. They gave me a copy of the printout for my records. Also they told me to bring the car back after a couple of thousand miles and they would re-check the alignment again and correct it free of charge within 3 months of having it done (if it needs it).
To have both the near side front and rear wheels realigned they charged me £24.95 per wheel plus VAT. Time will tell if I notice a difference. I had two new front tyres fitted as well so until they are "driven in" I am not going to be throwing the car round any bends :rofl:
Probably a bit far, but I had 4 wheel alignment done at Foxboro' Tyres in Eastry (nr Dover) totally solved the saw toothing at the rear, iirc £50 all in. :thumbup:
Formula 1 in maidstone are very good and have the hunter geometry package which is widely awknowledged to be the best setup around.
Great !, many thanks for your replies, much appreciated, I'll give F1 a call
