number plate festoon bulb length
Searched everywhere apart from dismantling the car.........
How long are they?
Daz
Is that the same on the Fabia vRS?
Cheers mate :).
Also will the ones off autobulbs trigger the bulb warning?
If they say canbus they are OK, I would always ring to check,I once ordered some from superskoda for the doors and they were totally wrong :thumbup:
I found the canbus ones but they are out of stock.
i found these but i dont know if they will fit due to the width???
Didn't think the Fabia was CANBUS? Thought it was only the main lights the warning worked with?
Oh i don't know then i thought it was
confused.com
Don't think so anyway. Could be wrong, but thought Canbus was later (new design of cars from 2004?) onwards.
Edited by TriggerFish
mines a 2007 Fabia vRS so it could be?
Anybody have any suggestions on the link i posted?
Good or utter garbage? :)
Sorry, I meant cars designed and launched from 2004 onwards, like the Citroen C4, the VW mk5 Golf, the Octavia 2 etc, rather than ones designed in say, 2000, like the Fabia.
Although DRJ is viewing, and I'd guess he knows more than I. :thumbup:
Shouldn't that be "he knows more than I do" ? :giggle:
My understanding is that the numberplate light is not covered by the bulb warning system since the manual states:
The warning light  comes on if a light bulb is damaged:
• brakes applied (brake light),
• in lighting (low beam and/or rear light).
A peep sounds as an additional warning signal.
Hence the reason you can fit LED front sidelights without a problem - at least I hope so - I ordered some today!
But then it also states:
We therefore recommend that you have any bulbs changed by a Å koda Service
Partner or, in exceptional cases, by calling on other professional assistance.
Touché sir, touché.
