HELP! Apex RDX Coilovers
Hi I have just got myself a set of Apex RDX Coilovers and tried fitting today and couldnt work out where the anti roll bar drop link fits on the damper there doesnt seem to be any fixings on the damper for the anti roll bar to connect to? is there a specific way of doing this? or do you need to modify the drop link?, I would appreciate it if anyone could help me on this as I am stuck with this one. Many Thanks :thumbup:
i think you have to order the right one for your car, as i think only the vrs have droplinks. do some research tho
Ok mate thanks i was informed they were the correct set for the vrs i am starting to wonder now!
All Fabias have a front anti roll bar so not sure that you have.
As above, all fabias have an arb, you got part number or photo of struts??
ApexRDXkitlg.jpg These them?
Yep these are the ones I have! are they the right ones?! They did fit my car when I had the car jacked up etc but wasnt sure where to connect the ARB :S .... Thanks
Edited by MonkeyNutts
The ad thing about using pics off the net is they only really use a photo for illustration purposes, is one photo to cover the whole range!!
Looked up eBay and it gives two part numbers in two different ads, the correct ones should be rdx80-023...
If there is no where on the struts to attach the links then they are probably the wrong ones I'm affraid!!
