Cut out.... i hate it
Bought my Fabia (2000 1400 16v) over a year ago, couple of days later the POWER STEERING pump died. Replaced with genuine part. .... ££££££!!
Fine for 13 months then..
Car started revving its self, (had been doing this on & off for 6 months) EGR flow fault code, cleaned, all fine. 2 weeks later same.. a day later same and ENGINE MANAGEMENT light.... so i bought an EGR!! £££!
few days later...
my steering went again, showing same symptoms (i thought typical, pump just out of warranty!!) BATTERY REPLACED (electric pump) all fine!
starts revving its self again!
going down the motor way last night 80mph, ENGINE CUT OUT completely, OIL LIGHT on, checked oil .. fine.
started engine (first time) steering locked
turned off engine, started again, steering fine, managed to get back but kept below 50mph
car felt underpowered, and 'twitchy' on steering
checked ALT this morning output fine!!
H . E . L . P!!!!!
Get the fault codes scanned - it's all guesswork otherwise! :S
calling up no fault codes unless problem is happening :(
i used to love this car, now seriously thinking about getting rid!!!
any ideas would be fantastic!
If im honest it sounds like a bit of a pig in a poke, would probably end up being more cost effective to just swap it for another with all the problems as it sounds like a load of electrical faults...
Does it not log fault codes that have happened recently? Purely guessing here ;)
Where abouts are you located? Might be a member on here with VAGCOM / VCDS willing to help you out :-)
If you're in the Norfolk area I can.
putting it on diaogs now...
nah im s wales :(
ta anyway
just got it back
no fault codes present..
non in memory ..
:S :S :S :S
It starts OK, I take it?
If the work was done at a Skoda dealer then I think genuine replacement parts have a 2-year warranty. I'd certainly be asking the dealer to ask Skoda to make a contribution as the very expensive pump they replace should definitely last longer than a year. That's assuming they did actually replace the pump and it wasn't the alternator or a dead battery that they actually replaced.
no they just replaced the battery this time!
im in Parts lol so no-ones gona pull a fast one! but thanks!!
anyways!
i just wanted to say a big thank you to everyone thats helped
just got it back from another garage 5 fault codes found
inc eng elec, brake elec, air bag, instrument elec, steering elec
MAJOR ECU FAULT
but on the bright side my heating and a/c works fine lol
Bye Bye Skoda :'( ... shame really, its only got 53thou on it an is perfect in every other way :(
THANK YOU!!!!
anyways!
MAJOR ECU FAULT
THANK YOU!!!!
I wonder if those faults might be from changing the battery, and not anything to do with the actual fault? I seem to recall I get lots of random faults when the battery is disconnected!
Don't give up on the poor Skoda yet :-(
no problems started before batter change, just looked at a tasty lil fiat! :p
