fmic help
putting one on the golf
whats best basically.... bar and plate or tube and fin?
also a good source to get one from, don't want to spend mega bucks and also don't want ebay rubbish
also anyone got sizes for either seat sport fmic or forge fabia so i can get a rough idea of what i need
Tube and Fin - Pros
Generally weighs about half as much as a bar and plate core of similar dimensions
Generally less expensive
Generally less flow restriction within the core than bar and plate designs
Less flow restriction through the exterior allowing better flow to the rear of the core and to a radiator, AC condenser, tranny or oil cooler, etc. which may be behind it
Cons -
Those with less flow restriction than bar and plate cores offer less heat rejection
Generally have more fins which means they're more likely to be damaged by rocks/debris which cuts down on cooling efficiency
Charge air entry extends beyond core wall making it more difficult for air to enter the core cleanly
Bar and Plate - Pros
Generally off greater heat rejection than tube and fin design
Those with turbulators offer even greater heat rejection
Offered in tons of varying shapes and sizes
Less likely to be damaged by rocks and debris
Charge air entry sits flush with core allowing for cleaner entry
Cons -
Weighs about twice as much as a similarly size tube and fin core
More expensive
Blocks more airflow to radiators, etc. which may be behind it
Those with turbulators have greater flow resistance to the charge air
just out of interest how come your taking the charge cooler off?
right oh so whats the best then lol?
also wheres a good place to buy
ebay coolers made of cheese yeah?
