dinger not dinging?
this morning, my dinger to say the temperature had dropped wasnt working, it went to 0.0 then -0.5 and no dinger? :doh:
The low temperature chime works when the temperature drops below 5°C - it only goes off once. So assuming yours went off when you started the car, it won't go off again until the temperature's gone above 4°C and then dropped again.
The outside temperature indicator will appear with a snowflake symbol (warning
signal for ice on the road) ⇒ page 14, fig. 8 and a warning signal sounds* when the
outside temperature lies between +5°C and -5°C.
[Corrected following subsequent posting and test]
Edited by DRJ
IME, if it's below 5 degC when you start the car, you just get the snowflake and temperature flashing on the dash (to start with; it just stays on after ten seconds or so) - it only bongs if the temperature DROPS below 5 degC while driving...
Correct - and I should have tried first as I have now!
The display changes automatically from whatever it was left at previously to the temperature display as noted...
Edited by DRJ
:SSo all is ok? :S
Yeah, fine.
Octavia may be different from Fabia but I get a bong when starting engine when snowflake is on
I'd stab puppies if I could make mine not bong ever for temperature warnings.
