HELP PLEASE, possible boost leak
hey, just on the drive home from work tonight i noticed a hissing noise, not too loud but def wasn there before, im assuming its a boost leak where all do i check?
many thanks, jordan :)
Check all the pipes are connected together properly and all the clips are nice and tight. Also check for any splits in the hoses
thanks, by hoses you mean the intercooler pipes?
Yes i believe there are rubber hoses on the standard piping? That's what u have yes?
im just not sure where to look for the rubber pipes? i know the main intercooler pipe running up the left of the engine bay when your looking at the car, other than that not too sure where to look?
Yes that's the inlet pipe from the intercooler going into the engine, I think the other pipe is underneath that pipe. I think u can see the piping if you look under the drivers side wheel arch lining or you could remove your front bumper, then u will see better
ok thank you
FIXED, :) too the arch liner out to see the 90 pipe feeding the intercooler had come off somehow, cleaned it all up and clipped back on. job done :)
thanks for your help :)
