Coolant Pipe Replacement
Hi all,
I have just had to be recovered from Trafford Centre all the way back to Dewsbury in rush hour because one of my coolant pipes has split!! :wall: Can anybody help me to identify the correct pipe that I need. It is down the right hand side of the car (as if you were at the front of the car facing the engine). It also branches from one pipe into two. That is all I know and it is too dark outside to try and find any clues from the car. Does anyone know what part I need and also what is the part code?
Cheers,
Dean
Edited by deanyboy1985
Hi guys,
Just had a good look under the bonnet and i've found the offending pipe!!! It runs from the right hand side of the engine up to a t-section. It has the following details on it:
TEKLAS TR TE1
600 122 157 AA>EPOM/PEROX<
ZO.23.03.01
Could anyone tell me if any of this is the part number? I think this will be a really easy job to do looking at it as have only got to take the pipe from the turbo off to get at it.
I have pictures if anyone needs them to help further.
I look forward to your replies! :thumbup:
Dean
