What does this mean?
I have just tested my VRS for the first time and this fault code came up, i guess it isn't serious but can someone let me know what it means, as i can't find it on any fault code lists. Obviously it is to do with the radio but what specifically? Thanks
Address 17: Instruments
Controller: 1U0 920 911 C
Component: KOMBI+WEGFAHRSP VDO V07
Coding: 19412
Shop #: WSC 31480
TMBER41U638675863 SKZ7Z0B1511567
1 Fault Found:
01304 - Radio
49-00 - No Communications
Address 19: CAN Gateway
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 31480
1 Fault Found:
01304 - Radio
Do you have an aftermarket radio? Even if you did the above means nothing to me. :D Ross? ;)
No it is a standard radio. The reading on the actual radio block is.
Address 56: Radio
Controller: 1U0 035 161 C
Component: Radio GRO 0001
Coding: 00403
Shop #: WSC 04804
No fault code found.
have you checked the fuses? It might be one of the wires that go to the ignition. Does the radio turn off when you pull the key out after turning off the engine, as that may be a symptom
Do the faults erase?
The radio works fine, the faults erase but then come back after a drive. Seems very odd ..
Yes the radio does turn off when i remove the key, isn't it supposed to??
Mine doesn't switch off when i remove the key.I remember one day at work though i must have fogotten to switch it off and when i came back the knob was out but the radio was off,so maybe they switch off after a pre set time.A 2001 model vRS by the way.
The knob will stay out if you use the key to turn it off and not manually, this is how it should work. Try it and see, if it does stay on with the key out it is the S wire fuse, but will turn off anyway after 30 mins to conserve the battery. The auto interior light will not come on either if it is the fuse
To get to it, in the Manual, look at the fuse box bit for the S wire (or something similar).
The fuse box is in the side of the dash next to the steering wheel, oppposite to in the manual.
yes, I was just wondering it it was not, as it may have been a fuse.
So my radio is working correctly then, i wonder what these codes can be.. Ross to the rescue ;)
