Skoda Roomster VCDS Coding
Playing with my Roomster which has rear electric windows, I wanted to set 1Click Open all doors and on lock to close all the windows.
The initial coding of module 46-Central Convenience was 00018 which seems to make sense as Central Convenience coding, Auto Window Close + 4-Door, according to the table below
So I changed it to 00259, which I thought would be Central Locking with 4 power Windows (Front & Back) + Selective (Single) Door Locking inactive + 4-Door.
However the 1 click open all doors works fine but the windows don't close.
Am I understanding something wrong or can you not make the windows auto close on locking the car.
00016 - Central Convenience coding, Auto Window Close
00064 - Central Locking with 2 Power Windows (Front)
00256 - Central Locking with 4 power Windows (Front & Back)
+00 - 2-Door with Selective (Single) Door Locking active
+01 - Selective (Single) Door Locking inactive
+02 - 4-Door
Post a complete Auto-Scan please, the coding table you are referring to hasn't been updated yet. But let's see if the newer stuff actually applies to your car first...
I did actually email Ross Tech with my autoscan and also the label stuff about address 17 and 25 as that is what their help said.
What does Auto Window Close mean ? Is it the windows shut on door lock from the keyfob or it a held down for a while door shut on the key fob ?
By the way: I enabled Auto Lock, Auto Unlock, Unlock bleep and Lock bleep on Adaption Channels 3, 4, 6 and 7 all OK.
Wednesday,17,November,2010,20:34:59:45213
VCDS Version: Release 10.6.1
Data version: 20100831
Chassis Type: 5J - Skoda Roomster
Scan: 01 02 03 08 09 15 16 17 19 25 37 44 46 55 56 76 77
VIN: TMBMGxxxxxxxxxxxx Mileage: 33440km/20778miles
Address 01: Engine Labels: 038-906-019-AXR.lbl
Part No: 038 906 019 NR
Component: 1,9l R4 EDC G000SG 9134
Coding: 00102
Shop #: WSC 73430
VCID: 74EC67BC6EC9
TMBMG65J485038105 SKZ7Z0G4490603
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 6R0-907-37x-ABS.lbl
Part No SW: 6R0 907 379 C HW: 6R0 907 379 C
Component: ABS 8.0 front H05 0002
Revision: 00000000 Serial number: 00000000000000
Coding: 0002085
Shop #: WSC 73430 790 00000
VCID: 3E7885941005
Address 08: Auto HVAC Labels: 6Q0-820-045.lbl
Part No: 5J0 820 045
Component: Klimaanlage X0850
VCID: E2C091E4443D
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
Part No: 6Q1 937 049 F
Component: 0000 BN-SG. 2S36
Coding: 25742
Shop #: WSC 73430
VCID: 3E7885941005
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 F
Component: Q5 AIRBAG VW61 Q1Q2 0004
Coding: 20789
Shop #: WSC 73430
VCID: 275640F0EF9F
Address 17: Instruments Labels: Redir Fail!
Part No: 5J0 920 940 C
Component: KOMBIINSTR. V2824486
Coding: 19402
Shop #: WSC 73430
VCID: 2A50B9C4FC8D
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: 000E GATEWAY CAN 2S36
Coding: 00014
Shop #: WSC 73430
VCID: F0E4EBAC9AD1
Address 25: Immobilizer Labels: Redir Fail!
Component: IMMOBILIZER V2824486
Coding: 19402
Shop #: WSC 73430
VCID: 2A50B9C4FC8D
Address 44: Steering Assist Labels: 6Q0-423-156.lbl
Part No: 6Q0 423 156 AB
Component: LenkhilfeTRW V270
Coding: 10110
Shop #: WSC 73430
VCID: 6FE668D007EF
Address 46: Central Conv. Labels: 6Q0-959-433.lbl
Part No: 5J0 959 433 A
Component: 03 Komfortgerát 0001
Coding: 00018
Shop #: WSC 73430
VCID: 3162AEA8D15B
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 5J0 035 161 HW: 5J0 035 161
Component: Radio FO3 010 0029
Revision: 00010000 Serial number: SKZ7Z3G0091807
Coding: 0000400
VCID: DFC69810774F
Address 76: Park Assist Labels: 5J0-919-283.lbl
Part No: 5J0 919 283
Component: Einparkhilfe V005
Revision: 00012000 Serial number: 07101056461054
Coding: 0001120
VCID: EFE6E8D087EF
End ---------------------------------------------------------------------
Edited by aubrey
Sorry for the late reply. I've updated the coding table in our WIKI, as you'll see there is a break between MY 2007 and 2008 where they switched the door control modules from CAN onto LIN. That resulted in a different coding table as well. The coding information in VCDS has been updated too, so once we publish the next update this will be corrected as well. :) Guess all makes sense now?
We've received your files, and I hope to have 17 and 25 covered with a label file as well by the time the next update is being published.
Edited by Theresias
Probably a silly question but where do I look on the wiki as I can't find what I need, could you post a link ?
