Fabia II with TPM
Had intended to order some winter wheels and tyres from mytyres today for our Fabia II FL. Noted in the handbook and on the filler flap that 165/70 R14 is listed as an (winter) option. This size appears to work well in the snow on our Furby I and putting it through the tyre size calculator suggests it's almost a perfect match diameter wise with the OEM 205/45 R16 tyres.
However I also had a look at the Skoda Germany tyre and rim guide; unfortunately it appears if my translator worked correctly, that this size is not compatible with TPM/TPC systems :S
Can anybody shed any further light on this before I get bamboozled by SUK. Theres no mention of this potential incompatibility in the handbook as far as I can see.
Thanks,
TP
Edited by The Plumber
I'm not sure why that should be as its only a simplistic system which measures wheel rotation from abs sensors. Have changed from 16" alloys to 15" with 195/55 tyres and had no effect on TPM didnt even notice i has swapped wheels and the front two were at different pressures from the garage by about 10psi. :S got home reset pressures and the TPM and no light so far been a month.
May help, may not.
When you inflate or change tyres/wheels you have to press the TPM button until it Beeps. this will reset the system
