Alarm Trouble
Suddenly thsi afternoon the alarm went off, for no apparent reason. I relocked the car, but over the next hour or so it went off again and again. Colleagues suggested various fixes:
1. Relock all doors
2. Open and close everything.
3. Open and clean filler cap etc.
Nothing has worked - it still goes off evey few minutes, seemingly at random. I am fast losing patience with it, though it seems quiet at the mo.
I would therefore be grateful for any other suggested causes, and if possible a way to disable the alarm so it doent wake the neighbours all night.
If its relevant, it is below freezing, and was below -10 degrees last night, though it has always been fine until now.
Thanks in advance
The sensor is to sensitive.
With vag-com it can be lowered to more reasonable value.
A small insect inside could be enough to trigger the thing.
On my drivers door their is a button to desactivate the interior sensor.
I had exactly this trouble on a Fabia some years ago in cold weather. Turned out to be caused by a voltage drop. The Dealer replaced the battery and the alternator and it never happeded again.
On the Fabia if I kept my finger pressed on the keyfob lock button it deactivated the alarm. Not sure if it does on the Octavia....... Have to check that one out for myself. Oh I think you can press the button on the drivers side door pillar. That deactivates the internal sensor.
Not going to fix an electrical fault though but may help your diagnosis.
