Cornering Fog Lamps and Second Rear Fog Light
Deep vRS
Today I got my new VCDS lead and download the latest version of the software and I tried to do the cornering fog light and second rear fog light on my car but it didn't allow me to do this.
My car is a 2010 FL Octavia vRS without maxidot.
Anyone help? Below is a scan of the car if anyone needs it:
P.S. The radio malfunction is because I changes the original antenna to a shark fin one.
Tuesday,07,December,2010,17:06:36:55197
VCDS Version: Release 10.6.2
Data version: 20101123
Chassis Type: 1K0
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 56 62 72
VIN: TMBEH21Z2A*******
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (CEG) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 RD HW: 03L 906 022 GA
Component: R4 2,0L EDC G000SG 5751
Revision: 13H03--- Serial number:
Coding: 0001072
Shop #: WSC 73430 790 00000
VCID: 78F4E8B472AF
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AH HW: 1K0 907 379 AH
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 163B601C092A00FE680B06EB901E0082340800
VCID: 78F4E8B472AF
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 3T0 907 044 AR HW: 3T0 907 044 AR
Component: Climatronic H15 0401
Revision: 00005001
Coding: 0000000002
ASAM Dataset: EV_Climatronic A01006
ROD: EV_Climatronic_SK35.rod
VCID: 82000A5CA473
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 087 D HW: 1K0 937 087 D
Component: BCM PQ35 H 103 0575
Revision: 00103 AG
Coding: 4E180AB8B05BB1C040080080110001E4430000AE424D8160800440040000
VCID: 32601A9CD453
Part No: 1Z2 955 119 C
Component: Wischer 11011 22 0601
Coding: 00D7B7
Part No: 1Z0 951 171
Component: Innenraumuebe 008 5101
Part No: 1K8 951 605
Component: LIN BACKUP HO H09 9002
Address 10: Park/Steer Assist (J446) Labels: 3C8-919-475.clb
Part No SW: 1Z0 919 475 B HW: 1Z0 919 475
Component: PARKHILFE 4K H06 0006
Revision: -------- Serial number: 66641000905142
Coding: 100002
VCID: 408440546AFF
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: Q4 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD2J428+
Coding: 0020788
VCID: 3D7A39A01D0D
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CQ HW: 1K0 953 549 CQ
Component: J0527 053 0111
Coding: 0000034
VCID: 830E0F58BB69
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 1Z0 920 903 J HW: 1Z0 920 903 J
Component: KOMBI H06 0305
Serial number: 00000000000000
Coding: 410B00
Shop #: WSC 73430 031 00000
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
VCID: 3C7C34A40617
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H16 0233
Revision: H16 Serial number: 4520K101080139
Coding: E9A07F06000202001303
VCID: 69D2BDF03905
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H06 0305
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03005
ROD: EV_Immo_UDS_VDD_RM09_SK35.rod
VCID: EAD042FCBC03
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1T0 959 701 T HW: 1T0 959 701 T
Component: Tuer-SG 009 2114
Coding: 0000756
VCID: 4894587442CF
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 74 3001
Revision: 00H17000
VCID: 31621590D155
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1T0 959 702 R HW: 1T0 959 702 R
Coding: 0000756
VCID: 47965B484FD1
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1Z0 035 156 F HW: 1Z0 035 156 F
Component: BOLERO 009 0053
Revision: 0A001001 Serial number: SKZ1Z3I8184356
Coding: 0D0004000001
VCID: 356A2180253D
1 Fault Found:
00856 - Radio Antenna
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 2
Reset counter: 35
Mileage: 1740 km
Time Indication: 0
Date: 2001.14.06
Time: 18:13:09
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 5K0 959 703 A HW: 5K0 959 703 A
Component: Tuer-SG 007 2101
Coding: 0000144
Shop #: WSC 73430 790 1012544
VCID: 32601A9CD453
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 5K0 959 704 A HW: 5K0 959 704 A
Coding: 0000144
VCID: 336E1F982B49
End ---------------------------------------------------------------------
Cornering lights should be
[09] Central elec / Coding / Long coding helper / byte14 / bit 5, Check the box.
ESC / DO IT!
2nd rear fog is unavailable on a FL
That's basically it, but take a look at Byte 14. Bit 7 ;) Also see my notes about the turn signals and/or turning the wheel:
Cornering Lights via Front Fog Lights active
Found in Coding, Long Coding helper
Notes: The lights may work under the following conditions:
- The headlights must be turned on and the steering wheel must be in the turning direction.
- Headlights on, fogs off, turn signal on in the turning direction. Also see Byte 17, Adaptive Light/Cornering Light Variant. This seems to control the fogs as cornering lights with turn signal.
That's from this post: http://forums.vwvortex.com/showthread.php?4743553-VCDS-MKVI-MK6-Platform-Handy-Coding-tweaks
This shouldn't be related to the lack of dash MFA/MFD/ maxidot. The "Corner" or "Bends" lights on the dash are for the Xenon AFS steering lights, not the fogs as turns.
