VRS Fabia II Fuel, Oil and Tyre Pressures
Hi All,
This puts together information I have researched, mostly by contacting Skoda Customer Services, regarding the owner maintenance of the Fabia II VRs 1.4.
Fuel is 98 octane or above; 95 only in an emergency (prolonged use of 95 WILL cause engine damage due to pre-ignition)
Oil is Castrol Edge (recommended) 5W-40
Tyre pressures (converted to psi from Bar, rounded to whole numbers) 36psi Front, 34psi Rear (up to 43 loaded, Estate; Hatch may be different, please check)
If you doubt the accuracy of this information please contact Skoda Customer Services for confirmation.
Regards
Tony :yes:
