Spigot Ring
I went to put my new wheels (Octy vRS) on today and noticied that they wouldn't fit over the hub, when I looked there was this plastic/rubber looking ring which I've now been told is a spigot ring. I bought the car with the current wheels on (Pro Race 3's), if I get this ring off using a screwdriver/chisel will I need another different spigot ring to replace them with or are they meant to be bare for standard wheels?
Spigot rings are only usually needed to adapt aftermarket wheels. All the OEM wheels should have the correct 57.1mm centre bore and fit direct onto the hubs.
