Wheel Spacers
Ive got them on mine, they are good quality but steel so heavier than the alloy ones, but they are bolt on hubcentric so they bolt to the hub then your wheels bolt to them using the OE bolts, I still feel thats better then using longer bolts although there isnt anything wrong with that.
Bottom lot is a set of four though, but 20mm is to much for the front.
Justs picked up some 15mm FK spacers for the rear of mine but suspect I might have wanted a set of 20s... wil post pics when they are on...
15s may not fit, some do and some don't. Not all are deep enough to sit flat on the disc and bottom out.
Iv got 10mm on the front and 20mm on the back, dropped on weitec coilovers all the way on the back, then with 7 threads left on the front. The spacers are ones from shark performance, hubcentric ones, and there great. I'd post a picture if I was on the computer, hope it helps
