Brakes: Brake Fade Causes And Cures
Pad Fade
Pad fade occurs for several reasons. All friction material (brake pad stuff) has a coefficient of friction curve over temperature. Friction materials have an optimal working temperature where the coefficient of friction is the highest. Sometimes you can use the brakes so hard that you get the temperature over the point of maximum friction to where the coefficient of friction curve starts to decline.
The mechanics of this decline in the coefficient of friction are varied. At a certain temperature, certain elements of the pad can melt or smear causing a lubrication effect, this is the classic glazed pad. Usually the organic binder resin starts to go first, then even the metallic elements of the friction material can start to melt. At really high temperatures the friction material starts to vaporize and the pad can sort of hydroplane on a boundary layer of vaporized metal and friction material which acts like a lubricant. Pad fade is felt as a car that still has a decent, non mushy feeling brake pedal that won
Fluid fade
Fluid fade is caused by the boiling of the brake fluid in the calipers. This produces bubbles in the brake system. Since bubbles are compressible, this makes for a soft spongy pedal. In worse cases, the pedal can plunge to the floor with very little slowing! Fluid fade can be avoided by running a high grade racing type brake fluid and/or frequent changes of brake fluid. Also if you change the pads before they get super thin, the remaining friction material will help insulate the calipers from the heat. Some people have had some success with having swaintech spray thermal barrier coating on the backing plate of the pads to help isolate the heat but I have never tried this.
Fluid fade usually has a gradual onset.
Reducing fluid fade
Fluid fade is caused by boiling of the hydraulic fluid in the brake system usually in the calipers and even sometimes the lines under hard use. This localized boiling allows bubbles to form in the brake
The final type of brake fade is "Green Fade"
Green fade is a type of fade that manifests itself on brand new brake pads. Brake pads are usually made of different types of heat resistant materials bound together with a phenolic resin binder. These are thermosetting plastic resins with a high heat resistance. On a new brake pad, these resins will out-gas or cure when used hard on their first few heat cycles. The new pad can hydroplane on this layer of excreted gas. Green fade is dangerous because many people assume that new brakes are perfect and can be used hard right off the bat. Green fade typically will occur much earlier than normal fade so it can catch a driver that is used to a certain car
  • 2 years later...
:bump: for Bengie and Eddie
  • 3 months later...
An 06 Furby vRS won't let you drag the brakes to sort out the green fade, any alternate suggestions?
  • 5 years later...
Great info :thumbup:
Holy thread revival Batman!
jesus christ i was 12 at the time when this was written :L :L
