Brakes binding
Hi all,
On the way to Biringham today the car the brakes started to bind "front left"
When i took the brakes apart the piston would not retract. I managed to get the piston out and the
and it had a rusty patch on it.
Link below sell Felicia pistons but they dont look like the same cup shape "cup shape" - but will it still work?
http://cgi.ebay.co.uk/SKODA-S-SERIES-BRAKE-PISTON-44-5mm-APPRX-/120649481278?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item1c1744fc3e
Where can i get a service kit "seals
car is a S reg 1998, 1.3 mpi
That's not a Favorit/Felicia piston in the link, that's for the rear-engined S100/S110 that predated the Estelle ;)
Skoda list a service kit with a new piston and seals for about £12. Other motor factors should do similar. There's no difference between Felicia and Favorit calipers, and I believe it's also the same Lucas caliper as used on the front of some Ford Sierras (certainly the pad fitment is the same).
  • 4 weeks later...
Ive been trying my best to find the relevant kit and no luck.
Dose anyone have a part number as im sure rust will appear on the piston again and i will be stuck - again.
I need the piston as well as the seals.
Thanks all......
54mm piston in a felicia caliper, try a local motor factor, the piston kit is very readily available for those, rebuilt both mine last year
Or if you want to try a dealer, the Skoda part number is 6U0 698 471 D for the kit of piston, seals and new caliper bolts.
Excellent....just what i wa looking for!!!
Thanks to all.
Dang it I'm cursed! :'(
Every time I mention a part that I haven't yet touched on my car, it promptly breaks - this morning I notice my front left is binding, and I know the pins weren't anywhere near seized when I last looked. Oh well, guess that caliper refurb isn't going to wait until the summer - at least I don't have to look up that part number again!
Rang up the Skoda dealers today and quoted the part number and i will be collecting it on Saturday morning.
the one benifit of the calipers kits are the are very quick to change and cheap.......£9-10 per caliper.
Edited by brian1.9diesel
