Non-standard fitted sat-nav
Will this sat-nav fit in the (Fabia Mk 2) vRS?
yes, it should.
Should do. There's someone else doing a straight fit aftermarket VAG head unit. My only concern is that on the Fabia3, when you engage reverse the stereo turns the volume down a little and shows a display for the sensors. I'm not sure if these aftermarket head units do this. May sound daft, I know. But if you spend a lot of money on a stereo that looks factory fit, you kind of want it to act the same.
If you buy a Mk2 vRS (without the sat nav option) are all the necessary connectors/wires behind the dash so you can fit one later ?
Sort of. There is no Sat Nav antenna and the car will need to be coded to know it now has Sat Nav. Assuming you have Maxidot then it should all work like the factory installed unit. And I've yet to see an Amundsen on ebay.
Now that I like
Cool camera options, great alternative view if you could mount the front one alongside a DRL.
Installation intructions made intresting reading :yes:
Now that looks very nice... HSBC, can I borrow some more wonga please?
