What gearboxs fit a mk1 vRS?
Hi
My clutch is ready for replacement, and my 1st gear has been whining for the last 20,000 miles. So im looking around for a gearbox, I figure I may aswell have it replaced while the clutch is done if ecenomic to do so....
The transmission code on the label in the boot is EHA, however looking arround on Ebay I cant find many/if any available. Are there any other golf/A3/leon varient gearboxes that fit the Mk1 vRS? 5 speed or 6 Speed?
Many thanks
and Merry Christmas.
Edited by r300chris
Hi
Many thanks
Not 100% sure but a few months back i had to change my gearbox, a mate of mine who owns a garage changed it for me but also said that the Octavia will only work properly with EHA gearbox, he mentioned that the speedo may give a false reading and that the mpg will drop if using a different code gearbox, took me four weeks to find a second hand box, ended up finding it on eBay.
Hope this helps
merry Christmas a little bit late and happy new year
Hope this helps
Hi,
Any 02J petrol 5 speed from an Audi A3 (non - quottro), Seat Leon, VW Golf or Bora will fit without too much fuss. ****** about speedo reading, mine's spot on with the 6 speed!! The only way it'll effect mpg is if it's too lower geared.... But the petrol 02J's are all the same final drive.
Steve
Hi,
Steve
sorry, just repeating what i was told, ill know for next time :)
cheers
Hi sorry to hijac but I cant find the guide for the 6 speed conversion, iirc someone did a nice write up of them putting a 6 speed box in the vRS, it was silver iirc?
what is needed to do this as from what I gather the 6 speed boxes are much stronger than the 5's in the vRS?
cheers
billy
drive shafts
flywheel and clutch
starter motor
selector and cables
not worth the money unless running big power then its meant to be good
second hand 02j boxes are going for £100 these days
I did a guide..... Will find a link to it! Regarding the parts it's like Clive said with the addition of the modification to the clutch hydraulic line.... Oh and the 02m specific mounting bracket.
The gear selector cables can be retained as long as you have the correct cable support guide on the top of the gearbox casing - nothing gearstick end needs changing.
It's a massive job and if you're running less than 330bhp I really wouldn't bother! 02m (petrol) is too shorter geared IMO, and the 02m (diesel) needs some serious poke to make it work well!
In gear speeds are approx @ 7k limit:
02M (petrol)
1st - 32 mph
2nd - 56 mph
3rd - 87 mph
4th - 112 mph
5th - 138 mph
6th - 162 mph
02m (diesel)
1st - 55 mph
2nd - 88 mph
3rd - 125 mph
4th - 155 mph
5th - 180 mph
6th - 180+ mph
The 02m diesel box is kind of similar to the 02j...... Gears 1-5 are similar geared just approx 15mph faster in gear, and the extra gear (6th) is an ultra smooth (very) high speed cruising gear!!
Steve
02M (petrol)
1st - 32 mph
2nd - 56 mph
3rd - 87 mph
4th - 112 mph
5th - 138 mph
6th - 162 mph
02m (diesel)
1st - 55 mph
2nd - 88 mph
3rd - 125 mph
4th - 155 mph
5th - 180 mph
6th - 180+ mph
Steve
i can second all of that!!!
