short shifter
Does anyone has a shortshifter?
Is easy to fit? Are any downsides? I drove my friend's MK2 VRS 6 speed short shift and I love it
All infos are welcomed
Man,your website is top benchmark... :thumbup:
One question....how do you remove this from the cable?
IMG_0176
It's really easy - you push the knurled bit up to the square end compressing the spring and the middle part pops apart, allowing the whole end to slide off.
i have a ebay shortshifter. much shorter throw and a lot less play. finding a suitable gearknob was hard though. just fitted superpro dogbone bushes too, makes the change smoother .
ive been lookin at these too
http://cgi.ebay.co.u...em=280588133485
are they ok for fitting , mine is 2001.....
Some one has fitted one of these, can't remember who though, pretty sure it was a black VRS
i have one, i fitted it myself, but its a pain to do, need proper access from underneath really.
Both myself and Oet have these fitted.
Very nice mod. B1tch to fit DIY on the vRS, mega-b1tch to fit on the 4x4 (prop-shaft & exhaust in the way)
Has to be fitted from underneather. Exhaust and heat shield block access ...
I did a DIY guide also on the Forge quick shifter.
Pic of the standard VRS gear shifter and linkage
Forge Short Shifter with the 3 optional fitting adapters(depending on which one you have fitted to the car)
Difference between the 2 gear shifters
Original shifter removed
Forge short shifter fitted and in place
Easy job to do and happy with results, Gear shift is a lot less gear throw
Next was the Verdict Motorsport gear shift bushings
http://www.verdictmo...roductCode=0100
I heard about these whilst browsing the VW forums and also our Rob's website as he has these fitted. Ordered from this US website at approx $22 did not break the bank so I gave it a go.
Can see the original rubber mountins on the left verses the solid Verdict mountings on right.
Removing the originals is easy, I memoved the selector cables off the gear linkinage arm as i was replacing that with the forge and was going to do a linkage adjustment anyway. Then I just undid bolts and lift bracket up.
removed the original rubbers
Placed in the verdict replacements
bolted down
Then I reset the gear box linkage
good vid here which is helpful.
http://www.youtube.com/watch?v=tp9ggefOjAE
