Fitting a decat
Are there any guides on this? I can't see any!
Really all I need to know is how to get too the three bolts in the engine bay, you don't seem to be able to access these at all easily! Is it an airbox/engine cover out kinda jobbie
merry Christmas everyone :) hope your all having a good day
I dont know if its different on my 07 fabia mk1 vrs to others (as there is a few differences) BUT my cat was roughly under my gear stick and I had it cut out and a stainless steel pipe fitted in place £30, Better sound without more volume. Hope this helps
Yea that sounds the same as mine. I have a brand new magnex decat so need to swap the whole section over. I assume you had the whole section taken put to have your bit welded up? Do you know if they got to the bolts in the engine bay area through the bonnet or from underneath the car?
I tried to do my mates one a while ago from under the car but it was too difficult like that
I have a full milltek Inc de cat and mine is a daily driver and no problems just sound soooo much better  good luck with it 
Did you fit it yourself?
He done it all whilst it was on the car unbolted a few moutns to get it to hang down a little to weld the top.
How did he get to the mounts? I am guessing it was the bolts in the engine bay side of the system?
