Air vent removal
Hi all,
Does anyone know how to remove the passenger side air vent please? I have a terrible rattle that the dealer has failed to fix twice and I have given up with them now and am going to have a go myself
Cheers, Halflife
I dont Know but have similar problem especially after 15 minutes or so of driving when temperature gets hotter
I managed to figure it out, you pop the long trim off, the one that runs then length of the dash (split in the middle where the hazzard button goes). I used the plastic edge of an ice scraper to make sure I did not damage the trim. This exposes the underneath of the air vent and there is a cut away on the right hand side. Get a hook of some description and pull the vent out (no screws or anything). I then greased all the areas where i could see that plastic contacts with plastic and re assembled. Time will tell if i have fixed it or not
Halflife
Edited by halflife1973
Did you fix it and can you tell me what you lubricated it with ? - I have a rattle from the drivers side air vent . I assume removing the drivers trim is as the passenger side
Regards
Chris
Regards
Chris
Gets more like a VW everyday.
