FAULT CODES OCTY VRS 2006 HELP!
Hi I have just had the codes read on my octy 20 litre vrs 2006 if you can help please let me know
They are:
05699 CHECK DTC MEMORY OF ELECTRIC LOAD CONTROLLER P1643 UPPER LIMIT REACHED INTERMITENT.
00801 ENGINE SPEED SENSOR(628) IMPLAUSABLE SIGNAL P0321 WOTA PLAUSABLE SIGNAL INTERMITENT
12402 OXYGEN(LAMBDA) SENSOR BI SI: INTERNAL RESISTANCE IMPLAUSABLE P3266 WOT A PLAUSABLE SIGNAL INTERMITTENT
Anyone have any ideas please give me a shout
Thanks for looking people
This post has been edited by crf450r2: Today, 17:36
Read my current thread about the engine speed sensor, otherwise known as the crankshaft possition sensor, http://briskoda.net/forums/topic/184320-octavia-ii-19tdi-pd-engine-speed-sensor/ this might help with that problem.
I think the oxygen sensor may be part of the MAF sensor, if so i found a guide online on how to remove and clean them (saves buying a new one).
Does the car run?
I would start by replacing crank sensor then clear the codes and see what returns. The top code maybe present due to the other codes. Any exhaust mods?
Hi
The car runs but only revs to 3500rpm.
There are no mods as completely standard.
What do you think?
Hi
Just so you all know it was the crank shaft sensor!
Now it goes like a rocket with better fuel consumption!
