Engine Oil?
I've just used the last of the Castrol SLX 5W-30 which was supplied with the vRS to top the oil up, on looking at the spec for this oil on the web it appears to be for the PD diesel engines?
Its to VW 504 00/507 00 spec in the handbook its says that VW 502 00 spec oil should be used?
What oil are you using in a 180VRS & if this oil is the wrong one I'm confused as to why it came with the car?
