Multi Dot display...KPH to MPH? (new Fabia vrs)
Hi all,
Is there anyone out there that knows if the small kph multi dot display can be changed to mph on the new Fabia vrs.
Also is there a dash brightness dimmer switch anywhere,looked everywhere,but I think i am out of luck!
Many thanks Wayne.
Hi all,
Many thanks Wayne.
No and no :no: Two issues covered previously on the non vRS facelift fabias. There is a way you can get it to display MPH by telling the ECU it is an Australian model via canbus I believe or something similar but nothing straightforward.
As far as I know you can't change the kph to mph - by law the spedo has to show both mph and kph, but the dial only has mph, hence the digital display of kph.
Not sure about the dash brightness though.
regarding the dash lights, there is no dimmer switch only lummi 1 and lummi2 in the radio set up
the only difference between the two is that one lights up the radio on/off button and one doesn't. noticeable more in the dark
(Fabia Blueline Mk11)
Edited by Auric Goldfinger
Thanks for the replies guys.
Pretty much what i guessed.
Happy new year and thanks again. W
