How tricky? Timing belt change on 1.9 TDI
I've had a bit of experience with mechanics, done a couple of timing belts on older cars in the past. Just want to know what's involved and if you need any special tools to do a belt change, water pump, pulleys etc... on a 1.9 TDI fabia?
Cheers,
Matt
Thanks Mike.
Has anyone done a timing belt on this engine? any pointers?
Cheers,
Matt
It can be done without but I would suggest you buy or borrow the correct engine locking kit.
They are around £30 on fleabay and make the job much easier.
Grab a haynes manual or buy an elsawin electronic manual - takes much of the memory out of re-assembly.
You will need to support the engine whilst the engine mount is off.
